Prefab shower drain installation - slab on grade
Rutherfordman
DIY Member
North Carolina
This is probably not rocket science but could someone walk me thru how to install the drain on my new prefab shower base. I have a 2" PVC pipe in a box out (slab on grade)for the shower with the trap below slab. I need to buy the correct drain from one of the big two home supply stores. Which one do I get? Also how do you get everthing water tight and adjusted properly when you can't get to anything from below or the side?
