PPfister compression shower faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by dleach9000, May 21, 2008.
  1. dleach9000
    dleach9000 New Member
    May 21, 2008
    Shower problem:
    My Pfister, compression shower w/diverter not in wall, but on the tub downspout.
    My hot water leaked, the fixture was some worn, probably could have done a washer replacement, replaced the stem fixture complete. After I replaced the stem, I have no leaks, but no water coming from the downspout either. And the cold water that used to flow ok, now has no flow.
    I have checked all of the parts, fitting looks just like old model. What happened?
    Also cold water assembly is STUCK.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    A lot of issues here/
    For starters, on this type of valve, whenever you install or remove a stem, it should be in the intermediate position.=, i.e. not fully open, not fully closed. That may be why you have one stuck.
    You should take everything apart again and look for debris...old chunks of washer, etc, which may be blocking a port
Similar Threads: PPfister compression
Shower & Bathtub Forum & Blog Need vintage compression nut Mar 20, 2016
Shower & Bathtub Forum & Blog Persistent shower leak after Sayco compression valve rebuild Nov 2, 2015
Shower & Bathtub Forum & Blog Upgrading shower stems from compression to quarter-turns May 9, 2015
Shower & Bathtub Forum & Blog Pfister - Change Compression to Ceramic? Feb 9, 2014
Shower & Bathtub Forum & Blog Fiberglass shower base with compression drain Mar 23, 2010
