Power cord for plama TV
Discussion in 'Electrical Forum discussion & Blog' started by gehrigc, Jan 21, 2008.
  1. gehrigc
    gehrigc New Member
    Jan 21, 2008
    The cord it comes w/ is SJT cable and isn't as long as needed. I bought another cord but realized it's SVT.
    I don't know much about the difference, but doing some research, looks like the SJT is for hard usage/service and the SVT is a vacuuum cord.
    1) What does hard usage/service mean?
    2) Can I use the SVT cord instead of the SJT?
    Gehrig
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Looks like the main difference is the SVT cord is designed to be more flexible. They're both rated similarly, although SJT is available in larger wire sizes. Oddly, though, one vendor's 12-3 SJT is only rated for 10A, the same as the 18-3 SVT. Let's wait for BobNH to respond; he'll know.
  4. gehrigc
    gehrigc New Member
    Jan 21, 2008
    Thanks for the response.
    I forgot to mention that both cords are rated 18AWG / 3C.
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I'm pretty sure either would work fine in your application.
  6. jadnashua
    The big thing probably is how much longer is the new cord? A plasma doesn't draw a huge amount of energy, but then 18g isn't all that big, either. If you are going to buy one significantly longer, I'd probably want to go with a heavier gauge wire. You don't need the PS working harder than needed because of voltage drops.
  7. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    just out of curiosity, where is this tv located that the cord will not reach a receptacle?
  8. enosez
    enosez Member
    Jan 27, 2007
    Supv Maint Oper
    Long Island NY
    What exactly is a "plama" tv?;);)
  9. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    18AWG wire is good for 7Amps, I believe. That should be enough for atleast 800 Watts. If you want to consider the voltage drop, it'll be approx 6.5 Ohm/Foot.
    I would just get a 14AWG three-prong extension cord and use the stock cable.
    Jason
  10. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    I would just rough in a new receptacle behind the tv so you dont even see it...;)
  11. kd
    kd New Member
    Dec 11, 2006
    Are you running this extension cord inside the wall so the TV installation looks neat ? It is against the Code to run extension cords inside a wall or cabinet. It is OK to run TV and computer cables inside a wall.
  12. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    That doesn't sound right to me, but I can't check the details right now. Maybe off by a factor of 1000 or so.
  13. Lakee911
    Aug 23, 2005
    Columbus, OH
    Yup. Off by 1000. That's the resistance per 1000ft. Sorry about that. :p
    http://www.stealth316.com/2-wire-resistance.htm
  14. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
  15. mikept
    mikept DIY Senior Member
    Jan 14, 2008
    CT
    Lakee did you mean milliohms? Or were you sugesting toaster wire?
  16. Lakee911
    Aug 23, 2005
    Columbus, OH
  17. mikept
    Jan 14, 2008
    CT
    =6.3851mOhm/ft
  18. Lakee911
    Aug 23, 2005
    Columbus, OH
    Yup. Same thing.
Similar Threads: Power cord
Electrical Forum discussion & Blog Dishwasher Power Cord Jun 30, 2012
Electrical Forum discussion & Blog Installing a Dryer 30 Amp power cord, 120/240 volt. what gauge wire? Sep 18, 2009
Electrical Forum discussion & Blog Power feed problems Monday at 10:55 PM
Electrical Forum discussion & Blog New Outlets= Erratic Dimming Power Jan 10, 2017
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
