Pouring Lead Toilet Flange
Discussion in 'Toilet Forum discussions' started by Amatuer123, May 22, 2006.
  1. Amatuer123
    Amatuer123 New Member
    Feb 26, 2006
    Hello, I decided to remove the complete old flange and lead in my concrete basement and have some questions. While hammering the old flange I must have hit the lead? pipe riser and it now has a half inch (from top) hairline crack which is visible on the outside and inside. Don't know if the crack is a problem; surface of riser is still flush and will be partially surrounded by lead. Also, I will be adding back concrete I assume around the flange and don't know what order to do this. I assume I'd lead it first. For now, I have this order planned:
    1) Set flange to proper height; i.e 3/8 inch above floor for 3/8 inch tile.
    2) Fill w/ oakum and lead. How much oakum and how much lead? (too what level) At this point the flange is @ 1/2 inch higher than the riser if the flange is 3/8 above the floor and hope this isn't a problem.
    3) Fill concrete around flange after lead sets.
    4) Tile floor.
    5) Set/secure flange to concrete.
    Any advice is much appreciated. Thanks in advance, Joe
  2. Cass
    Cass Plumber
    Nov 12, 2005
    There are a few different types of PVC flanges that you might want to consider. They go inside the 4" and may block/cover the crack. The crack may cause problems down the road when / if anything leaks out or the crack lenghtens. The flange should set on top of the finished floor.
  4. Amatuer123
    Feb 26, 2006
    Hairline Crack
    Thanks for the advice Cass. I'm coming to the point where I may become a gongoozler because I don't want to mess this up. I'm wondering if there's a way to fix the crack? I'll do some research and maybe call a plumber. Thanks again, Joe
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Maybe I don't understand what you said but lead won't crack.
    The stub looks like steel pipe or cast iron that has been cut with a band saw.
    Either way you need to use a cast iron flange.
  6. Amatuer123
    Feb 26, 2006
    Thanks Plumber1. I'm planning on pouring a lead joint w/ oakum, etc., and hope this all works out. The riser will be about a 1/2 inch below the top of the cast iron flange so I'm assuming I'll pour the lead up to the height of the riser and I will reduce any negative effects of the hairline crack.
  7. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Yes, but you should use a deep flange to grab enough of the riser......
Similar Threads: Pouring Lead
Toilet Forum discussions Pouring muratic acid in the flush valve Nov 28, 2016
Toilet Forum discussions Rough in toilet before pouring slab Nov 29, 2007
Toilet Forum discussions Lead toilet drain worth replacing? Aug 27, 2016
Toilet Forum discussions Oatley Twist-N-Set into Lead Bend? Nov 12, 2015
Toilet Forum discussions Toilet flange - cast iron and broken lead closet flange Nov 8, 2015
