Plumbing and floor plan
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by brosnt1, Feb 15, 2006.
  1. brosnt1
    brosnt1 New Member
    Feb 10, 2006
    Can a professional plumber plumb new construction regardless of the floor plan. is there always a way to accomplish the plumbing.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    10 times out of 10, yes. If the framer doesn't make allowances for certain crucial drain stacks in the home, the framer has to come back and either move joists or header them off to make it work. Floor plans designed by any architect, engineer, carpenter hold a large part of the responsibility of how things *mesh* in the design and planning of DWV systems installed by plumbers.
    Short of a electric chain saw or sawzall, all things are possible with a plumber. :eek: :D
  4. hj
    plumbing
    As I told a carpenter foreman on one job where the rough floor was also the final floor, "You can cut the opening I need to put the plumbing in, or I can do it. The only difference will be that I will not worry about how you will be able to put it back." All things are possible, as long as you do not get discouraged.
Similar Threads: Plumbing floor
Plumbing Forum, Professional & DIY Advice Plumbing Design for new 2nd floor bath--which one? Nov 16, 2016
Plumbing Forum, Professional & DIY Advice 2nd Floor Plumbing Layout Jun 27, 2016
Plumbing Forum, Professional & DIY Advice Plumbing comes through floor at an angle Jul 1, 2015
Plumbing Forum, Professional & DIY Advice Does this cast iron look okay to use for two floors of home plumbing? Apr 16, 2015
Plumbing Forum, Professional & DIY Advice Feedback on plumbing floor plan layout-advice needed May 3, 2014
