Hi all, I am in the getting ready to install a water softener and would like to add a second standpipe in my basement. Access to floor drain in not practical as it is located in the walking path of the laundry room. I currently have the setup in the photo. The trap and vertical 2" pipe is for the washer drain. The 1 1/2 vertical pipe on the left is the vent going to the roof. The horizontal 2" pipe at the bottom is from a bar sing roughly 5 feet away which is vented (or re vented) correct me if I'm wrong, back to the 1 1/2 inch vertical on the left.
How can I add a second drain? Could i put a 1 1/2 inch trap above the existing trap? Or a better way. Maybe somehow tying into the horizontal and the into the vent above. I should also mention that I have a condensate pump, and a R/O system that I need to use these 2 standpipes for.
Not sure where to go.
Any advice appreciated.
Thanks
Thanks
