Plugged 2" copper drain
Discussion in 'Drain Cleaning' started by Nyrik, Jan 11, 2017.
  1. Nyrik
    Nyrik New Member
    Jan 11, 2017
    Massachusetts
    Can anyone tell me if it is more common to find a 2" copper drain plugged or a 2" PVC drain?
    Also, Should I just replace the copper drain pipe with PVC?
  2. hj
    Neither one is more likely to clog than the other, and there is no reason to just "change" the copper line if it is not deteriorating and leaking.
    MASTERPLUMB777 likes this.
  4. Wrenched
    Wrenched In the Trades
    Apr 20, 2011
    Vancouver, BC
    I'd say it's way more common to see blocked 2" copper, but that's mostly because it's likely older and had more time to develop a build up. It's uncommon though not unseen for copper DWV to be installed in a new build.
    The only reason to replace copper drainage is if it's failing, it's installed poorly/has caused a lot of issues, or if it is quite old(50yrs+) -and- a major renovation will make it hard to replace in the future.
  5. Sylvan
    Sylvan In the Trades
    Sep 23, 2004
    New York
    Personally I like to use no hub cast iron as the ells are long radius which makes snaking a lot easier and because of the mass CI is really quiet.
    Also PVC requires a lot more Clevis hangers ( I hate band iron) as PVC can sag and cause back piching and bellies in the piping
