Please help
Discussion in 'Shower & Bathtub Forum & Blog' started by Rob0177, Jan 30, 2008.
  1. Rob0177
    Rob0177 New Member
    Jan 30, 2008
    First post here so any help would be appreciated. I just got done plumbing my shower. One of my shower heads is a 8 inch moen rain head and it is coming down straight from the ceiling. My question is, the pipe goes up an interior wall into the attic about 2 inches. It then runs parallel to the bathroom ceiling about 18 inches and then back down about 5 inches where it is connected to the shower head. I would like to know if that 18 inch pipe that is in the attic will freeze or will the water all drip out since it runs parallel to the ceiling when the water is off. What would be the best thing to do. The pipe is in between the drywall and insulation in the attic already. Should I get one of those foam rolls that have a slit in it and put it around the pipe or should I move the pipe back into the actual room and convert it to chrome since it would be visible
  2. Rob0177
    Rob0177 New Member
    Jan 30, 2008
    Here is a picture to help explain. It goes into the attic about an inch or two then over to the rain head then down 2 inches. Will this pipe in the attic freeze. Thanks Rob
  4. Cass
    Cass Plumber
    Nov 12, 2005
    I would at very least have the pipe pitched downward toward the shower head and have lots of insulation above it.
    Weather it will freeze is like asking if you will win the lottery. Being in the attic it obviously could but weather it will is another question that can only be answered in time based on many to many variables.
    The valve piping looks good although I can't see it well.
  5. hj
    pipe
    As a practical matter, the shower head will probably not allow air to enter the pipe so the water will stay in it, and freeze if it gets cold enough.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Rob, Knowing where you are located would help in the guess of freeze or , not but it would still only be a guess... Key West Nah it won't... Minot, North Dakota more than likely!
  7. Rob0177
    Rob0177 New Member
    Jan 30, 2008
    I am in Nebraska. Would it help to build a wood frame around it, insulate inside the enclosure and then drywall it.
    Is there another way to do this or is this the only option.
  8. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Wait a minute - everybody read the original post again.
    You said the pipe is in between the drywall and the insulation - so it's under the insulation? - on the room side of the insulation?
    If so, it's already inside the room, temperature-wise. The fact that it's outboard the drywall doesn't matter, it's where it is in relation to the insulation that matters.
  9. Rob0177
    Rob0177 New Member
    Jan 30, 2008
    It is under the insulation. The Drywall is on the cieling, then the pipe, then insulation, then lots of cold air.
    This is what I thought but then I read or somebody told me that it would freeze.
  10. Rob0177
    Rob0177 New Member
    Jan 30, 2008
    Wouldn't the water run out of the pipe going to the attic and come out the lowest faucet when I turn it off. I think that I might insulate the pipe with foam then the attic insulation then frame in the piping in, drywall it then through more insulation over it. That is about as much as I think I can do with out moving it back into the actual shower.
    Sorry I am so paranoid but when we moved into or house a few years ago we had a pipe break (not)our fault) but it flooded the entire house so it worries me
  11. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You are paranoid, but that OK. Your pipe won't freeze because heat from the house will penetrate the ceiling drywall and with insulation on top of the pipe, there will be enough heat to prevent freezing. I would not put foam insulation around the pipe itself, that would block the heat from reaching the pipe. Remember, insulation does not heat anything. It only slows heat transfer and you don't want to slow the rising heat from reaching the pipe.
  12. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Throw some 3/4" insulation on the attic pipe, making sure to cover the joints.
  13. jadnashua
    The horizontal portion of that pipe in the attic would be best if it had some slope to it to allow some water to drain out the head, but like a soda straw with your thumb over the end, may not drain. In a tub with a divertor spout, it opens both ends, so it drains. When you have a valved divertor, one end stays sealed. You might get some water out after you've turned off the water by playing with the divertor so it is partially opened (some don't work that way, they turn off one port completely before it opens the next) and allowed the rain head to drain through one of the body sprays.
  14. frenchie
    Dec 30, 2006
    Caretaker
    Disregard what Denny said (no offense, Denny) - like Gary said, wrapping the pipe in insulation would be counter-productive.
    If you're really paranoid, add regular insulation on top of the existing insulation in the attic.
    But it should be fine. Thermally speaking, the pipe is already inside the bathroom.
  15. srdenny
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Actually, best case scenario is the way he's running it, sandwished between the ceiling drywall and the attic insulation. I didn't read his whole post.
Similar Threads: Please help
Shower & Bathtub Forum & Blog Help please with tub replacement Jan 9, 2016
Shower & Bathtub Forum & Blog Please help me find this hinge from framed shower door Jan 9, 2016
Shower & Bathtub Forum & Blog Help Identify this Auburn Brass set please :) Dec 19, 2015
Shower & Bathtub Forum & Blog Rusty Drain, New Condo, Marble Floor, Unknown Material - help please Dec 14, 2015
Shower & Bathtub Forum & Blog Diverter leaking from inside tube. please help identify/locate part Sep 12, 2015
