Hi guys. My friend has a 10" x 4.5" whole house filter housing right next to her house. I want to replace it with a 20" x 4.5" housing to increase water flow. I know very little about plumbing.
I've already bought the 20" housing, but the threads on the housing do not match the threads on the old housing cap, which means I must remove the old rust-colored cap between points B and C in my photo.
Looking at my photo, can I just use wrenches to unscrew the pipes at points B and H?
If so, can I connect flexible plumbing to points B and H and connect them to my new assembly? The reason I want to use flexible plumbing is so the new housing can rest on the ground to prevent putting weight on the old plumbing. The new housing cap has 1" diameter threads on the inflow and outflow.
Is the white substance on the pipe threads teflon tape?
