Pipe clogged - weird going down
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by milo, Oct 28, 2012.
  1. milo
    milo New Member
    Oct 28, 2012
    Miami
    Hi everybody! It's a 1 story home, no cellar, old iron pipes. There was a hole with a leak,in a pipe in the outside wall, which I patched and it's not leaking anymore (opened the outside wall and just patched the hole. this only leaked when the washing machine ( not a new one) was pumping out the water. After the hole was closed, the water comes back up in the kitchen sinks when the washing machine pumps the water out, which are above the former leak. First you can hear it bubbling a bit, then it comes up about 1/2 inch in the sink, stalls for 2 sec and the drains out just fine. Smells bad and the water isn't clear with bits of stuff in it. No other back ups in the house. And there's no water backing out where the washing machine hose is stuck in the drain pipe.Is that a regular clog and I need to get someone to clean the vent?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The washing machine pumps out many gallons of water very quickly, which can easily overload a pipe which is partially restricted. It's time to start snaking the line and seeing if it can be cleared.
    I am concerned with what you call a "patch", as there is no good way to patch a hole in a pipe. If a pipe has a hole in it, the entire section of pipe might be going bad and should be replaced. If the pipe has more holes in it, it could be collapsed and just draining into the ground, which can seem similar to a regular clog to the user in the home.
  4. milo
    milo New Member
    Oct 28, 2012
    Miami
    I know that the "patch" will have to be replaced, it's at a big joint, looks like a big job. I'm just wondering about the way the water comes up, and then drains fast, I would expect a clogged pipe to drain the water slowly, but this one doesn't. It comes up, stalls and goes down fast.
  5. hj
    There is no "normal" pattern for a clogged drain, and your description sounds like one.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    You need to get the drain rodded out. It's not the vent.
Similar Threads: Pipe clogged
Plumbing Forum, Professional & DIY Advice The culprint of clogged pipe; Oatmeal Apr 23, 2014
Plumbing Forum, Professional & DIY Advice Well water possible clogged pipes bad water pressure Jul 24, 2013
Plumbing Forum, Professional & DIY Advice Branch Pipe of Cast Iron Waste Pipe COMPLETELY clogged! HELP!! Jun 23, 2012
Plumbing Forum, Professional & DIY Advice Clogged pipes ..... HELP !!!! Jun 7, 2012
Plumbing Forum, Professional & DIY Advice Cast iron pipe clogged - this is not good May 15, 2011
