piggyback float installation
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by gclay, Mar 8, 2008.
  1. gclay
    gclay New Member
    Mar 8, 2008
    The switch and float on my sump pump is failing and I would like to install a piggback float to circumvent the standard float and switch. I am no electrican but I purchased a piggback float at Home Depot plugged it in but it will not operate the pump. The piggyback system does have a 3 pronged receptacle and the pump is 1/3 HP. Can anyone provide advice? BTW, my plumber suggested the piggyback option and said it was easy for a DIYr to handle.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Are you sure you bought a Pump Down Float? They come both ways, up and down.
    I have Float switches with a 10 or 20 foot cord that come in pump down and pump up. You need a pump down not the up cord.
    bob...
  4. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    You need to make the existing float switch be ON all the time. You can often do that by raising it and wiring it in place.
    If the switch has failed completely then you may have to bypass the switch altogether. The details will depend on how your switch is arranged.
    You might be able to go into the switch and connect the cord directly to the wire that goes to the motor. You may have to waterproof the connection if it is below the water level. You can do that with a kit such as is used with submersible well pumps.
  5. gclay
    gclay New Member
    Mar 8, 2008
    Bob, that did the trick, wired the switch to on and it works! Thank You!
Similar Threads: piggyback float
Pumps and Tanks Well Forum & Blog. Water is life. Solenoid valve and Float switch Voltage, wiring? Tuesday at 2:45 PM
Pumps and Tanks Well Forum & Blog. Water is life. Float switch question Sep 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help choose / source floating level switch for well Jan 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Corded float switches Aug 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Storage Tank Float Switch Control System Sep 3, 2014
