PEX stub outs - how do you do yours?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TristanP, Jul 8, 2010.
  1. TristanP
    TristanP New Member
    Apr 20, 2010
    Delaware
    This is for the laundry sink on/in a base cabinet in the laundry room move I'm still working on. Would you go with this
    [​IMG]
    or this?
    [​IMG]
    I believe I have space for either. PEX is 1/2". Thanks.
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    That's fine. For a complete idea of all the PEX stub out and hanging options try Souix Chief's web site. If it's for plastic, they make it.
  4. TristanP
    TristanP New Member
    Apr 20, 2010
    Delaware
    Wasn't a yes or no, more of a this or that. :) Thanks. *off to check Sioux Chief*
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    There are a multitude of acceptable methods, if there was an aggressive water condition I would go with as much PEX as possible.
  6. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    If it was going in my house I would use the DE 90 and a brass nipple. Brass will hold up better than bent tube with aggressive water and repairs or alterations in the future will be simpler with less things that can go wrong. (No pulling of compression sleeves, for example)
  7. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    If I had too ( and mind you I wouldn't use pex for a dog house ) I would use bend supports and bring the pex right out through the wall and then you can just whack it off to the right length and use a Sharkbite stop and waste valve. Less fittings = less leaks.
  8. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    I used the drop ear type that you showed in your second pic. That allowed me to use conventional brass nipples and stops under all of the sinks. I have a home run pex system, and with all the issues with bad brass fittings in the pex world, I wish I hadn't.
    I've not had an issues but those are my one weak spot. I don't anticipate any problems with the tubing. If I did it again I would probably bring the pex out of the wall with those metal stud to stud brackets.
  9. hj
    If I were to do it, I would use the top version, but also place a Talon fastener on the horizontal section to prevent rotation.
Similar Threads: stub outs
Plumbing Forum, Professional & DIY Advice Two Stub Outs in Under Kitchen Sink? Garbage disposal woes... Jul 3, 2013
Plumbing Forum, Professional & DIY Advice Plumbing Stub Outs Apr 26, 2012
Plumbing Forum, Professional & DIY Advice Bath tub stub outs Mar 1, 2011
Plumbing Forum, Professional & DIY Advice Stub-outs Jan 1, 2010
Plumbing Forum, Professional & DIY Advice Covering pex stubouts Feb 24, 2009
