Pex or CPVC
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Cow_Chip, Mar 1, 2005.
  1. Cow_Chip
    Cow_Chip New Member
    Mar 1, 2005
    Not sure if I should post this here or in the remodel forum, so here goes.
    I live in a townhouse that was built in the mid 80's. Existing plumbing lines are Quest. This has been nothing but a problem since I bought the place. I have had nothing but water leak after water leak.
    I want to replace the plumbing, and was looking into either PEX or CPVC. I am trying to limit the total amount of wall damage that I have to do, so PEX is my leaning at this time. I figure that for my longest runs along each side wall I could use the existing line as a "pull line" for the new, and stub out the ends using the copper adapters.
    Should I use separate home runs for the supply lines, or copy what the existing lines look like now. (a standard installation with 1 major shut off valve)
    Looking for a few suggestions. This will be a fast moving project when I get started.
    Thanks
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    I'd copy what you have, there are pex angle stops, saves time when you use them, they crimp on just like the fitting.
Similar Threads: CPVC
Plumbing Forum, Professional & DIY Advice Freezing problem - Heat tape on PEX & CPVC pipe? Dec 12, 2016
Plumbing Forum, Professional & DIY Advice Simple way to connect pressure gauge to CPVC Sep 15, 2016
Plumbing Forum, Professional & DIY Advice Install traditional valve on CPVC/PVC pipe. Sep 14, 2016
Plumbing Forum, Professional & DIY Advice CPVC valve assembly Jun 27, 2016
Plumbing Forum, Professional & DIY Advice CPVC Fitting Advice Jun 27, 2016
