Pex A Cold Expansion Help
kmb8145
Phoenix
Re-doing all supply in my remodel. Using pex a as recommended by many. It’s all completely in, used the professional Milwaukee expansion tool for all manifolds and fittings. Now air pressure testing and using soapy water to find any leaks…I am getting small bubble builds in areas…these areas are on their second rebuild because they bubbles the first go around. This second time I used a heat gun to ensure a tight fit. I am at a loss since this is the second round and I am still seeing bubbles under pressure. I have asked a couple plumbing stores and professionals, they all have said to use water…I truly don’t want to cut and couple any more lines at this point…is the issue that I am using air and not water?
kmb8145
Phoenix
I am Uponor trained/certified. I'd use water.
I'd never see a need to use a heat gun for any fitting.
Thank you, it's been quite chilly and found the heat helped get things seeded quicker. I should be able to water test by this weekend. Will air escape where water will not?
John Gayewski
Iowa
Don't do a soapy bubble test. For one thing you don't know the chemistry of the soap and can't ensure it won't hurt the pipe. Second reason is you have three layers of material that are shrinking together. The voids that are shrinking have air in them. The air is forced out while shrinking.
When we do air tests your need a gauge. Go 1.5 times the operating pressure (60 psi would get tested at 90 psi) and wait 15 min. No longer no shorter. If the gauge hasnt moved your good. No soapy bubbles.
kmb8145
Phoenix
If the gauge hasnt moved your good. No soapy bubbles. >> meaning ignore soapy bubbles watch the gauge.
