Pentair Retro-fit
Discussion in 'Water Softener Forum, Questions and Answers' started by truckkerjoe, Apr 28, 2012.
  1. truckkerjoe
    truckkerjoe Member
    Apr 27, 2012
    Greensburg, MD
    Hello to all.. I'm new to this forum and looking for advice on retro fit on a pentair Model#7000 Conditioner head (carbon). This was purchased for city water chlorine application, which was never installed. We want to change it into a softener head. We found a dealer that might do this job but he wants all the parts first and ain't sure about all parts that are needed. After looking at the Service Manual we THINK it comes to this> ITEM NO.13
    - NO.9
    - No.12 two o-rings
    - No.5
    - No.4
    - No.18 ?
    - No.15
    - No.7 but what size Injector?
    - No.23 we have 45 Elbow on-it?
    - No.6 Turbine Meter but don't have No.17 Meter Cable Assy (looking for a complete parts for what is needed)
    Can someone HELP! We Have High Manganese(0.236) and Copper(2.06) Iron(0.0100) PH(7.34). This dealer said that this Conditioner head can work now with (greensand) and potassium permanganate solution by injecting it continuously, and back washing periodically. This will supposedly reduce water consumption (low-producing well is what we have), but we like a salt regeneration instead, which is why we are looking into a softener and trying to figure out if a retro is worth doing, or just buying a whole new head. THANKS to ALL you Professionals!!!!!!!!!!!
  2. ditttohead
    Jan 9, 2012
    Ontario California
    It will be about the same price to convert it to a softener vavle as it would be to buy a new valve if you upgrade the electronics at the same time. Is your valve an SE or SXT? When you plug it in, Blue is SXT.
    here ya go.
    40704
    19791-01
    40946
    61454-0 or 00 depending on tank size, either will work fine if your tank is 9-10 diameter
    61450-25
    61452-10
    40703
    12473
    40577
    40950
    61455-00 if your system has a 61456-..
    You will also need the 3/8" jaco nut and install kit for the brine line, a brine tank assembly, water softeing resin, and a DLFC button to match your tank size. 2.0 for a 9" tank, 2.4 for a 10" tank, 3.5 for a 12" tank assuming normal water temperatures.
    I have several dealers who will sell you the parts, these are all normal stock items, it is a fairly easy valve to retrofit.
    Depending on the age of your system, you may also want to upgrade it to an SXT version if it is the older SE, this woud also require that the cover be replaced.
    If your funds are adequate, I would highly recommend installing the carbon unit, a installing a 7000 softener after it.
  4. truckkerjoe
    truckkerjoe Member
    Apr 27, 2012
    Greensburg, MD
    Ok Thank-you so much.I will just buy a new head,Thanks again keep-on-truckken!!!!
Similar Threads: Pentair Retro-fit
Water Softener Forum, Questions and Answers Pentair 760 question Nov 21, 2016
Water Softener Forum, Questions and Answers Question - Considering a 5810 and Pentair Pentek ChlorPlus. Oct 9, 2016
Water Softener Forum, Questions and Answers Pentair/fleck 7000 not softening May 20, 2016
Water Softener Forum, Questions and Answers Pentair Water University Apr 20, 2013
Water Softener Forum, Questions and Answers Fleck Pentair 5800LXT first review Jul 5, 2012
