Patching a slab
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by corkym, Mar 15, 2009.
  1. corkym
    corkym New Member
    Nov 14, 2008
    I had to cut a hole in my slab so my plumber could get in and fix a cross
    connection.
    My question is, what's the best way to patch the hole. The slab sits on
    a red clay bed. The hole is about 18" x 18" and about 10" deep.
    Can I fill the hole with gravel or sand to the base of the slab or do I need
    to use red clay as the substrate like the original slab?
    Any recommendations for the concrete to use for the patch?
    I'm going to put porcelain tile on top of the patch.
    Thanks
    Corky
  2. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    Fill it with gravel and compact it as best as you can. Drill holes in each edge of the hole in the existing slab and insert rebar. Pour your patch with a bagged concrete. I use Quikcrete 5000 PSI mix just for the strength, but any will do. You'll need to treat the joint in the concrete with a crack isolation product before you tile. Noble makes a good product as well as several other companies.
  4. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Highly recommended you get advice on dealing with the new "cold joint" by posting at johnbridge.com, a tile forum much like this. Great people.
Similar Threads: Patching slab
Plumbing Forum, Professional & DIY Advice Patching LARGE hole around Sewer pipe in Foundation. Oct 28, 2011
Plumbing Forum, Professional & DIY Advice Patching concrete floor after rough plumbing Jul 16, 2009
Plumbing Forum, Professional & DIY Advice Patching Lead Pipe Mar 26, 2009
Plumbing Forum, Professional & DIY Advice Plumbing: Scheduling and Dispatching Nov 11, 2008
Plumbing Forum, Professional & DIY Advice What do I need to replace corroded cast iron drainage pipes underneath slab foundation? Jan 18, 2016
