Partially drilled into pvc
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Sherie, Feb 6, 2008.
  1. Sherie
    Sherie New Member
    Feb 6, 2008
    I was trying to hang a medicine cabinet and drilled a small hole into a vertical pvc pipe behind the sink, it didn't penetrate...I was using an 1/8" bit and the hole appears to be no deeper than 1/16".
    Will the pipe hold? Is there anything I can put on there to reinforce it?
    Thanks.
  2. D.Smith
    D.Smith New Member
    Feb 6, 2007
    Georgia
    Is this on the main floor? Is there a bathroom above it?
  4. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Is this a 1st or 2nd floor sink? Is there a bathroom or anything else above it? If there is nothing above it it could be just a vent and the only thing flowing through it is air.
  5. Sherie
    Sherie New Member
    Feb 6, 2008
    It's a one story home. The hot water heater is in the attic. The pipe is fairly large, maybe 2" and is not located directly behind the faucet, it's off to the side about 1 foot.
  6. D.Smith
    D.Smith New Member
    Feb 6, 2007
    Georgia
    HWH wont use pvc except as a drain in case of leakage. More likely it is a vent. I am not a pro but shouldnt have any problems with this. If you feel comfortable about cutting that section of pipe out and replacing it with a coupling it wont hurt.
  7. Sherie
    Sherie New Member
    Feb 6, 2008
    Thanks, I think you're right. I'm going to leave it be.
  8. jadnashua
    It should be fine as long as you didn't penetrate into the pipe...there is no pressure in it.
Similar Threads: Partially drilled
Plumbing Forum, Professional & DIY Advice Partially Closed Shutoff Aug 29, 2013
Plumbing Forum, Professional & DIY Advice joining ABS pipes partially under water Jul 12, 2013
Plumbing Forum, Professional & DIY Advice need pump test but well is partially blocked-jet pump? May 13, 2009
Plumbing Forum, Professional & DIY Advice 3 Stem Shower - Hot Water Causing Noise When Partially Cracked Open Oct 14, 2008
Plumbing Forum, Professional & DIY Advice Partially slow running drains? Aug 27, 2008
