I am installing a drainage system in an atrium that has one exterior wall. That wall has the same type of grade beam as the other 3 walls. The grade beam is 10 inches thick. I have measured the various elevations between the atrium and the existing positive drainage in the yard that I will tie into. I think the best way to get the pipe from the atrium to the outside yard area drainage system is to go under the grade beam.
My plan would be to build my own P-trap configuration under the grade beam from PVC fittings and pipe. For this discussion, I am calling the elevation of the pipe inside the atrium at the beginning of the P-trap to be at zero level (before it goes down). How much lower does the elevation of the pipe outside the atrium at the end of the P-trap (after it comes up) need to be for the P-trap to work properly and the drainage to work? Thanks.
