Outside spigot bangs when on low
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TonyLS, May 21, 2010.
  1. TonyLS
    TonyLS New Member
    May 21, 2010
    boston
    I tried searching the forum but couldn't come up with much.
    I just had an outside spigot installed at the front of the house, the original one is not in a convenient location. When I turn on the spigot low, say just a 1/4 turn to let the water out at a very slow pace I hear a very loud banging noise, or pipe vibration. This goes away once I open up the spigot, say a full turn to wide open. The plumber says it's due to high water pressure (I do have good water pressure). I'm not too concerned since I wouldn't keep the spigot on that low but I'm curious as to why it would show up now? The original outdoor spigot is fine when turning it on low, there is an expected noise of water being restricted but does not bang/vibrate loudly as the new one does at that same setting.
    I think the plumber did a great job plumbing in the new spigot, it's a very neat job.
    Any info would be appreciated
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    I had a case today where the outside tap had a loose washer that created a banging noise. It was a new installation, new spigot. Check to see if the spigot washer is tight. (Not the plumbers fault, its the manufacturer's fault)
Similar Threads: Outside spigot
Plumbing Forum, Professional & DIY Advice Replacement Stem for Outside Spigot Apr 7, 2016
Plumbing Forum, Professional & DIY Advice Timed inline shutoff for water line that goes to the outside spigot Jul 15, 2015
Plumbing Forum, Professional & DIY Advice Advice on new Closet Flange: 4" Spigot vs 3" outside fit Sep 23, 2010
Plumbing Forum, Professional & DIY Advice Outside Water Spigot. Apr 19, 2010
Plumbing Forum, Professional & DIY Advice Shut off valve for outside spigot calcified? Jul 18, 2009
