Outside Dry well
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BrianP, Jan 28, 2013.
  1. BrianP
    BrianP New Member
    Jan 5, 2006
    Illinois
    Older farm house. Foundation drainage and gray water both drain into an outdoor drywell. The drywell is about 12' deep and is accessed via a manhole cover. There is also a floor drain in the basement that connects to the well. At one time, there was a pedestal pump which stopped working and now we have a sump pump suspended in the well with a float switch. Water level gets too high, the pump turns on and discharges. The problem is if we loose power, the water backs up into the basement via the floor drain. There doesn't appear to be a way to install a backup system since you can only access from the top and it is so deep. The pump operates frequently with heavy rains combined with gray water usage from the house.
    I've thought about rerouting the graywater drainage to my septic tank to elinimate that. Still have the foundation drainage. Of course, the pump always seems to fail in the middle of winter and I have to be outside changing the darn thing.
    Any ideas about a backup system and how that could be installed? What about the idea of rerouting everything and installing a pit in the basement so I can easily access everything inside?
Similar Threads: Outside
Plumbing Forum, Professional & DIY Advice Water on outside of PVC vent pipe in basement Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Single valve for multiple outside hose bibs Jan 2, 2017
Plumbing Forum, Professional & DIY Advice First time in 16 years forgot to unhook outside hoses and turn water supply off Dec 16, 2016
Plumbing Forum, Professional & DIY Advice Drain pipe outside of kitchen sink on exterior wall Aug 22, 2016
Plumbing Forum, Professional & DIY Advice Natural Gas leak outside of house May 13, 2016
