Outside Breaker Trips
Discussion in 'HVAC Heating & Cooling' started by gmrules, Jul 4, 2008.
  1. gmrules
    gmrules Member
    Mar 19, 2007
    Computer Networking
    Raleigh NC
    I have carrier whos outside unit breaker trips as soon as it calls for air
    With Thermostat not calling for cooling breaks will not trip,
    Any ideas what I could check or what could be?
    4 years old, Just had PM done 3 weeks ago
  2. jadnashua
    I found a fried mouse across the contactor (relay) in the compressor unit last year on mine. It's guts caused the contactor to stick. One could have chewed through the insulation on the wiring, and could be the source, but it is more likely it is the compressor is shot. Depending on the unit, it might still be under warranty.
  4. gmrules
    gmrules Member
    Mar 19, 2007
    Computer Networking
    Raleigh NC
    its is under warranty but part only
    tech on phone said 90% its the compressor
    its one of those new puron carrier unit 10 yrs on compressor
    thought those new rotary ones are suppose to be so good
  5. jadnashua
    Scroll compressors are not new, but more and more manufacturers are using them. They can be more efficient, so that is the impetus. QA/QC may or may not be that great depending on where it actually was made. Some (few anymore) manufacturers make all of their parts, most now buy components from others and assemble them as their own brand, from what I hear. So, depending on the brand, the compressor may not be made by that company.
  6. geno54
    geno54 New Member
    Jan 4, 2008
    Could be a bad compressor, burned wire or even a bad or burned circuit breaker. Have had a few CBs that heated up on the busbar and tripped although you couldn't see it unless you removed the breaker. Time to call in a pro.
Similar Threads: Outside Breaker
HVAC Heating & Cooling Direct vent clearance to outside corner Feb 17, 2015
HVAC Heating & Cooling outside heating/cooling unit Jun 7, 2011
HVAC Heating & Cooling Return on an outside wall! Keep it, or shut it off and insulate the bay? Help? Jan 31, 2010
HVAC Heating & Cooling Outside heat pump not running at all Jan 10, 2010
HVAC Heating & Cooling My Heat pump outside unit stop working Feb 7, 2009
