OSB for Subfloor?
Discussion in 'Remodel Forum & Blog' started by molo, Apr 8, 2009.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    What problems (if any) can be caused by using OSB for subfloor.
    I'm asking because I don't need structural support, just a smoother surface to lay the luan on. You see... It's an old house with 1" thick boards for a subfloor (varying widths and slight thickness differences). :)
    Thanks for any replies
  2. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    The edges swells up, if it gets damp or wet. Doesn't hold nails quite as well as ply, either.
    Just use 1/2" ply, instead of the luan.
  4. jadnashua
    For a subfloor, I like Advantec, but for what you're looking for, ply is better, I think as well.
  5. molo
    molo Member
    Sep 23, 2006
    Cold New York
    I'll ditch the OSB idea. Can I lay linoleum directly over 1/2" ply and not have problems? What treatment do the seams receive?
    Thanks,
    Molo
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The problem with regular plywood is there may be voids here and below the top ply. A sharp weight such as an appliance or woman's high heel can break through. What you should use as an underlayment is called multiply. It comes in 1/4"x4'x4' sheets and may have different names. It's like plywood, but it has no voids. As I recall, it isn't much different in price from plywood.
Similar Threads: Subfloor
Remodel Forum & Blog Bathroom subfloor 1/2" MDO plywood adhesive? Feb 19, 2017
Remodel Forum & Blog Bathroom subfloor question Aug 11, 2016
Remodel Forum & Blog Subfloor question about vapor barrier Dec 2, 2015
Remodel Forum & Blog SubFloor Questions - How to secure new subfloor to existing structure Sep 11, 2015
Remodel Forum & Blog Basement Subfloor and Wall Insulation Dec 11, 2014
