Options for end of foundation / gutter drain pipe
ShelzMike
Virginia
At the end of last year, I installed a foundation drain (used sewer drain PVC corrugated, NOT the black corrugated pipe as it was a 7' hole backfilled with gravel) and it works very well! Hard work for sure, but worth it.
Anyhow, after it passes the corner of the foundation in the back, I transition to the corrugated black pipe to carry to daylight at the edge of my property line. I also have my front and rear gutters tied into a separate corrugated black pipe and it travels beside the foundation drain pipe to the same daylight location.
I definitely don't want to use a pop up for the end of these pipes but also don't really want to leave them loose. What are my options on "terminating " the daylight ends of these pipes? Should I just create a concrete form with a harder plastic fitting set in the concrete and have these pipes connected? Is there a better option? Thanks!
