Only hot and cold in bathroom sink
Maulydaft
TORONTO, ON
Thoughts on this:
Condo is 5 years old. For a few months we've only been getting hot and cold from bathroom sink. Had a plumber come in for our shower issue and mentioned the sink. He said "I could replace the cartridge in that sink but I don't think it will help..." and then proceeded to tell me why but since I understand little of plumbing I didn't retain it.
I have now learned how to replace my shower cartridge... should I bother with the sink? Aren't these cartridges supposed to last 10-20 years? What's going on? (Our shower cartridge was replaced in 2020 - only 3 years old)
Neil Binda
Toronto
Sometimes when you live in a condo the risers causes problems . You should look into that plus who makes the product .
John Gayewski
Iowa
Without knowing why you get one or the other (I suspect it would be a pressure differential problem) it's hard to say if changing the cartridge would help.
Maulydaft
TORONTO, ON
I don't even know what a riser is - hahaha! Sounds like something the management should be looking into? I'm assuming it's American Standard who made the sink fixtures as that's who made our shower fixtures and original toilet.
Maulydaft
TORONTO, ON
I'm also curious as to why this would be a problem only in bath sink and not shower or kitchen sink...
John Gayewski
Iowa
You should shut the stops under the sink and get a gauge. Check the pressure on the hot and cold lines individually. If they are reasonably close to one another there's no reason a new cartridge shouldn't work. Unless there's another problem with the handle or something.
maulydaft sounds like maybe you've got a cross over problem. the cold should be cold hot should be hot.
Your in a foreign country and I don't know how a condo is plumbed there. it could be that your hot and cold water systems are not independent of the neighbors So it could be from a valve in neighbors unit. does each condo have their own independent hot water heater or its just plumbed like an apartment
Maulydaft
TORONTO, ON
Hi there - well not that foreign - hahaha. Canadian plumbing is just like American. Thing is the water didn't change sides or anything. There's just no warm anymore. Just hot and cold. Yes, no individual water heater it's all in basement like apartment building.
