One-Pipe Hydronic Heating
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by techno, Feb 20, 2006.
  1. techno
    techno New Member
    Feb 20, 2006
    Hi, I'm installing a second zone on a hot water hydronic system with cast iron radiators. I'm using a one-pipe configuration with mono-flow tees. Is there a rule of thumb for the minimum distance between the supply and return tees on a radiator bypass? I'm using 1" copper main and 3/4" branches. Thanks very much for your help.
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    monoflo
    I believe it's at least the width of the radiation...
  4. hj
    tees
    Or else have an elbow between them.
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Here is a link to the instruction manual which describes spacing distances. There is a specified minimum of 6 ft between two different upflow risers, and the minimum distance between downflow risers is the width of the terminal unit.
    http://fhaspapp.ittind.com/literature/files/602.pdf
Similar Threads: One-Pipe Hydronic
Plumbing Forum, Professional & DIY Advice you will go with one-pipe monoflo setting or two-pipe reverse return setting? Aug 24, 2014
Plumbing Forum, Professional & DIY Advice Hydronic heat system freeze damage Nov 24, 2016
Plumbing Forum, Professional & DIY Advice Help sizing pex-al-pex for hydronic heating Oct 5, 2016
Plumbing Forum, Professional & DIY Advice Relocation Expansion Tank - Hydronic Heating May 4, 2016
Plumbing Forum, Professional & DIY Advice appropriately sizing a room's hydronic radiator requirements Apr 9, 2016
