Older Rainsoft LMB 1135
Discussion in 'Water Softener Forum, Questions and Answers' started by boazcan, Sep 2, 2013.
  1. boazcan
    boazcan New Member
    Sep 2, 2013
    tampa
    Hey Guys -
    Been nosing around here, but cannot find my specific issue discussed. If there is a link that you know, please post it and will go from there. Thanks!!
    I have an older 10/2000 manufacture date that I inherited with the house that we bought a few years ago. It has been working pretty good, but recently just stopped working. I didn't see a fuse or breaker on the control panel visable. I was curious the troubleshooting steps to figure out the malfunction. It will not manually regenerate. It has always done that with no problem. Seems to be no power to the control panel/head.
    Thanks for your time and assistance!
    Bryan
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Photo of the unit would help, but I will go with the Fleck 5000 like valve with the non digital set up, dials and wheels on the front.
    Either the timer motor is bad or if there is a trans former it is bad or both.
  4. ditttohead
    Jan 9, 2012
    Ontario California
    Picture please. Rainsoft uses pretty standard equipment. We can usually figure out what it is with a picture.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    If you have a multimeter check for voltage to the timer motor. If not check the transformer
  6. boazcan
    boazcan New Member
    Sep 2, 2013
    tampa
    Sorry for the delay, thanks for the feedback.
    [​IMG]
    [​IMG]
  7. ditttohead
    Jan 9, 2012
    Ontario California
    Wow, an old Intermatic timer. It is time for retirement.
  8. Akpsdvan
    Dec 29, 2009
    Alaska
    But the odd thing is that the date is 2000.
    I think it was one of the last of that timer but on say the 5000 valve?
    A photo from the back?
  9. ditttohead
    Jan 9, 2012
    Ontario California
    Agreed. I used that timer for many years on the old Schurz valve and the aquamatic nests. Bruner and more. I have only seen it on a few others, the piston driven aquamatic from the 80's? Please post more pictures.
  10. boazcan
    boazcan New Member
    Sep 2, 2013
    tampa
  11. boazcan
    boazcan New Member
    Sep 2, 2013
    tampa
  12. Akpsdvan
    Dec 29, 2009
    Alaska
    The last of that type of valve and control.
    It is time to look for a replacement rather hand trying to track down the parts for it as most likely you will not find them in any short order.
  13. Tom Sawyer
    Nov 29, 2010
    Maine
    Maybe eeeeee**** but i doubt it.
  14. Gary Slusser
    Retired
    www.craigslist.org is a more likely place to find an old used RS softener or control valve.
  15. Tom Sawyer
    Nov 29, 2010
    Maine
    See how easy it is to be helpful?
  16. boazcan
    boazcan New Member
    Sep 2, 2013
    tampa
    Is there a link to a replacement for this set up? I would rather replace it. Is it better to just buy an entire new set up? If so, what would you recommend? 4 person house, typical family setup. Thanks.
  17. Tom Sawyer
    Nov 29, 2010
    Maine
    You could probably use the old resin tank and maybe even the resin too along with the brine tank and float assembly and just change out the valve and distributer tube. There are a bunch of online dealers that would probably hook you up with a Fleck 5600 or a Fleck 7000SXT and the rest of the stuff you would need. If you go that route I think it makes sense to change out the resin rather than have to mess with it and wonder how many more years you can get out of it.
  18. ditttohead
    Jan 9, 2012
    Ontario California
    I would lean towards replacing the unit completely. Tom is right, you may be able to replace just the head, but... I dont have any of these in my "Museum" to see if the tank thread is standard or proprietary.
Similar Threads: Older Rainsoft
Water Softener Forum, Questions and Answers Softener in older home Feb 24, 2016
Water Softener Forum, Questions and Answers Older water softner. No seperate brine tank all in one tank Jun 15, 2015
Water Softener Forum, Questions and Answers Newbie with rainsoft system Dec 30, 2016
Water Softener Forum, Questions and Answers Rainsoft system leaking May 17, 2016
Water Softener Forum, Questions and Answers Newbie - Rainsoft equivalent alternative? Suggestions please. Mar 12, 2016
