Older Moen tub/shower valve leak
Discussion in 'Shower & Bathtub Forum & Blog' started by signstudio, Oct 25, 2007.
  1. signstudio
    signstudio New Member
    Oct 25, 2007
    I have had a leak from an 23 yr. old Moen (push-pull) tub spout... and am finally attempting to repair it. I disassembled the unit and replaced the cartridge. I believe I have the problem solved but now there is a leak coming from a screw on the brass housing itself, which was not noticeable before. I may have disturbed an o-ring when I tried steadying the unit with my hand, dismantling it.. rubber is slightly protruding on one side from around the screw. I am afraid to open it up, because I don't know if I will damage the unit beyond repair..
    of the two screws on the housing itself, it is the larger one on the right which is leaking...it is about an inch in diameter... the smaller one on the left seems to be fine.... I have tried to find some reference to a teardown on the internet, but am confused as to which one it is... it is old and probably is a discontinued model...
    Thank you to anyone who can help.
    Gayle :cool:
  2. jimbo
    jimbo Plumber
  4. signstudio
    Oct 25, 2007
  5. jimbo
    jimbo Plumber
    You have a Moentrol, like this>http://www.plumbingpartsdepot.com/moentrol.pdf
    The part that is dripping is the balancing spool. Apparently one of the o-rings got pinched going in. Get a new spool, or a supply house might have an o-ring kit for it. While it is out, use some crocus cloth , or 400 grit wet/dry to make sure the outer entry of the body is clean and smooth. Then use some plumbers grease or silicone grease on the o-rings, and try to reassemble.
  6. signstudio
    Oct 25, 2007
    Jimbo
    Great lead!
    I think I can take it from here and all should be okay
    Thanks again
    Gayle
Similar Threads: Older Moen
Shower & Bathtub Forum & Blog Older Moen Push-Pull? Aug 24, 2008
Shower & Bathtub Forum & Blog Older Moen Faucet Jun 16, 2008
Shower & Bathtub Forum & Blog Moentrol 3330 - pulling cart prior to soldering?! Nov 20, 2007
Shower & Bathtub Forum & Blog Older Grohe shower fauct cap removal Nov 19, 2015
Shower & Bathtub Forum & Blog electrical vs. plumbing solder Aug 16, 2015
