Old Delta Faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by scm23, Nov 16, 2008.
  1. scm23
    scm23 New Member
    Nov 16, 2008
    I have a delta shower faucet (just shower, no tub spout) and it is leaking out of the shower head. I opened up the ball valve and the seals don't seem to match the standard spring and seal in the repair kit that I bought. Delta doesn't show any diagrams that have a ball valve for the shower faucets only the cartridge style. Does any one know if the valves were different back then or if it's just so built up with deposits I can't see the spring?
    Thanks
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Yes in older Delta's they used a taller seat with a straight spring. That had to be somewhere in the 70's or, 80's when they switched...
    They are still available listed as a part for older Delta's and Peerless faucets.
  4. hj
    Delta
    The valves after the ones that used the tall washers, also used a ball but had the modern short washers and conical springs. IF you have not gotten to the point where you have removed the cap, do it gently or you will break the faucet and have to install a new one.
Similar Threads: Delta Faucet
Shower & Bathtub Forum & Blog Delta vanity faucets - again Feb 6, 2017
Shower & Bathtub Forum & Blog Replacement Delta bath faucet/diverter Nov 2, 2016
Shower & Bathtub Forum & Blog What's going on with this Delta tub faucet valve? Aug 3, 2016
Shower & Bathtub Forum & Blog Water leaking from back of dome nut (Delta single tub faucet) Apr 19, 2015
Shower & Bathtub Forum & Blog Delta Shower Faucet in Fiberglass Shower; Hole Size? Remove Plaster Guard? Jan 31, 2015
