Old cast iron shower drain re-do
Ripupthehwy
Cleawater, Florida
Would love some advice how to proceed here . Tiling OVER an old shower floor that’s on concrete slab floor . The house was built in 1965. Cast Iron drain not in greatest shape and drain cover is gone . Tiling over will require raising the drain . I really don’t want to bust up the floor and dig it out . Idk if there’s even a drain pan. Look like an inch or concrete or thinset . Considering just “gluing” a ring over drain to raise up (see pic with white ring in package) . Afraid if I do though may end up rebuilding entire thing if doesn’t work . Has anyone seen a drain like this ? If so what product or parts do you recommend to fix ? Thanks so much for advice .
John Gayewski
Iowa
I would bust up the tile and redo the drain.
If your building another shower here and you don't know if there's a pan then you have to build a pan. Why does breaking the concrete and redoing the drain effect you?
My Moms house in Palm Coast Fl has some funky style of shower pan it dosent even have a shower drain just a snap in crate expensive home on golf cource. 25 years old but I wouldnt remodel over it
Maybe thats just florida style stuff Ive got a theory on how the pans are built and suspect they have some sort of weep holes to outside the pans are depressed in the concrete. But I never seen how they were built. Id tear it out and replace it
Ripupthehwy
Cleawater, Florida
Just an update : I didn’t tear anything out and tiled walls and tiled over existing tile floor . Idk if there is or was any weep holes in this thing but have used the shower for 5 years without any water seepage . It’s built in a garage over concrete slab & everything about the shower is concrete including all walls . Im adding a sink and wall to “dry it in” as part of the interior of the house via a door in the wall between garage & house interior . Anyway , Would it be a dumb idea to drill 2 small holes on inside edge of the shower drain to act as a weep holes just as a precaution or could it cause a moisture problem ?
looks like 2 differant jobs unless you decided to leave it as is and re tile. in which case you already made the call. In which case Id leave it alone
Ripupthehwy
Cleawater, Florida
Yeah, after I grout it, I think I’m gonna use some kind of waterproofing sealant and leave it alone at some point the piping under the drain which is old cast-iron may have to be replaced but this is it for now
I dont think it has a shower pan in the traditional sence with a pre slope etc.
