Old bathtub drain problem
Discussion in 'Shower & Bathtub Forum & Blog' started by Dan_C_, Feb 27, 2009.
  1. Dan_C_
    Dan_C_ New Member
    Feb 27, 2009
    I live in an older building, built around 1930, with a remodel that was done probably around 40 years ago. My problem is this, my bathtub drain has stopped draining quickly, it gets the water gone, but takes its sweet time getting there. I have tried most of the natural remedies (baking soda, plunger, boiling water) and can make it a little bit better, but only for about a month or so.
    I bought a small affordable snake, but there seems to be a grating blocking my way getting it down the bathtub drain about an inch down.
    I rent, and can't do anything drastic, and as long as the drain is draining, the landlord won't do much.
    Is there a way to get around the grating without getting me evicted?
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Evicted¿ Landlord or slumlord¿ Might be a drumtrap that is in need of replacement for a traditional p-trap setup. Time to get a plumber out at the landlords consent.
  4. jadnashua
    A bathtub is often snaked from the overflow...on a really old one, getting that off without breaking something may be a problem...probably best left to a plumber.
  5. hj
    drain
    I assume from your description that you are trying to snake from the opening in the bottom of the tub. If so, STOP, you cannot do it that way. You have to snake from the overflow opening.
Similar Threads: bathtub drain
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Tuesday at 11:03 AM
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Drain Flange won't seal to bathtub Dec 21, 2016
Shower & Bathtub Forum & Blog Bathtub shoe drain too short Sep 15, 2016
Shower & Bathtub Forum & Blog Flexible PVC vs. fixed brass bathtub overflow/drain Aug 7, 2016
