EthylOH
Hi all,
Today I added new PEX lines to an existing copper setup.
The copper/PEX transitions are brass, so I used MAPP gas instead of propane.
One of the copper pipes was near a joist such that I couldn't get a good view of the solder job without moving the step-stool. Everything seemed fine, but the obsessive-compulsive, anal-retentive, can't-leave-well-enough-alone side of me decided that there wasn't enough solder showing on the other side, so I added more heat/solder to the joint within 30 seconds of initially forming the joint.
Is this joint compromised? I always thought soldering was a one shot deal, so should I cut it out and start fresh?
