Oil line valve open/closed?
Discussion in 'HVAC Heating & Cooling' started by rmelo99, Nov 4, 2008.
  1. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    I just replaced the nozzle and filter on the furance at my mother's house. Now I'm not sure which way the valves on the line is open.
    Is it the same as water valves? It's such a stupid thing but there are 2, on by the tank and another by the burner and each are a different style.
    They have the little screw in the center but I can't tell if clockwise is opening or closing the valve? Anyone?
    TIA
  2. maintenanceguy
    maintenanceguy In the Trades
    Aug 18, 2008
    Pennsylvania
    I can't see the valves from here but I've never seen a valve that opened "backwards" except on the cold side of a faucet.
    I would strongly suspect that they work the same as any water valve.
  4. rmelo99
    Jul 7, 2006
    Network Engineer
    I'm not crazy here but need a sanity check. They are weird in hoe they feel when turning, especially since the handle comes off if u twist enough in one direction. Water valves don't usually do that.
    So for my sake is the center screw supposed to be protruding in the open position above the handle? See pic attached.
  5. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    If I remember correctly from BPE school 40 years ago, the protruding stem means the gate is open ... but if you can screw the wheel (handle) off the stem, then something is wrong and the wheel cannot push the gate closed.
  6. maintenanceguy
    Aug 18, 2008
    Pennsylvania
    I've never seen a valve quite like that one.
    I have seen lots of OS&Y (open stem and yoke valves) with the exposed stem. Stem out means open, stem in means closed. Handle screwing off valve means you've got a problem. Maybe there's a set screw at the handle base to re-attach the handle to the valve body. Maybe it's just broken and needs to be replaced.
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Counterclockwise is open, stem out. Counterclockwise is closed, handle fall off.
  8. rmelo99
    Jul 7, 2006
    Network Engineer
    Thank you....is it just me or is there something weird about those valves?
  9. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    No, they have an inner sleeve that is soldered to an outer sleeve and if it get's hot enough the solder melts and closes the valve. They are code required at the tank and at the oil burner. They are there to shut off the flow of oil should a fire occur. There should be a similar such electrical device mounted above the boiler that shuts off the system in the event of fire also.
  10. rmelo99
    Jul 7, 2006
    Network Engineer
    Ok, that's good to know.
    I did all the troubleshooting that I could on this stupid burner.
    Installed new filter, oil nozzle, cleaned the ignitors and ceramics. Tested the transformer, cleaned the CAD sensor.
    I gave up!! Called in my furnace guy and he'll fix it!!
Similar Threads: line valve
HVAC Heating & Cooling Ductless Line Set Routing Sep 22, 2016
HVAC Heating & Cooling Torque wrench for copper lines? Aug 19, 2016
HVAC Heating & Cooling Air conditioner coolant supply line to attic Aug 4, 2016
HVAC Heating & Cooling Air combustion vent, ducts and in-line fan size? Dec 6, 2015
HVAC Heating & Cooling Does running two trunklines address the problem of trunkline duct being too small Nov 19, 2015
