Oil fired boiler
Discussion in 'Boiler Forum' started by Paso One, Sep 21, 2009.
  1. Paso One
    Paso One New Member
    Oct 14, 2008
    I am installing a small oil fired boiler Benjamin OB1000 90,000 btu in my shop. Is there any reason I shoudn't use the brand new type b vent pipe for the chimney that I have just sitting there??
    The manual says to use L type venting. Whats the differance between the two pipes.
  2. MAoilTech
    MAoilTech New Member
    Nov 24, 2009
    Oil Tech,HVAC
    MA
    Follow your state and local Codes if it tells you to use type L use it there is a reason.
    Type L vents are suitable for use with gas or oil. They can be used instead of a B vent, but a B vent can't be used instead of an L vent. In most cases, L vents are used with oil. Again, this is typically a double wall vent with an air space between. The inner wall is typically stainless steel and the outer wall is galvanized. Type L vents normally see temperatures of under 750F. Type L vents are tested for up to 1,000F.
Similar Threads: fired boiler
Boiler Forum Oil Fired Boiler Exceeds 30 PSI Pressure Mar 4, 2016
Boiler Forum Heat recovery from oil fired boiler May 20, 2015
Boiler Forum Oil fired boiler for domestic hot water? Jan 26, 2015
Boiler Forum Oil Fired Boiler With tankless Coil conversion to what? Jan 13, 2014
Boiler Forum Recommended replacement for ancient oil-fired boiler ? Gas boiler? Heat pump? Jul 10, 2013
