Dwitting87
So I just roughed in a bar sink in my basement. The lines tapped were for the bathroom sink overhead. I probably used more flux than is needed, but not overly excessive as I brush it on vs gobbing it on....in either case, it's been two days and I am still getting flux residue in the sink overhead.
I'm thinking part of this is because the rough in lines aren't being flushed since the sink isn't installed yet. The other paranoid feeling I have is that this is because I had too much flux.
I use oatey 95 because the oil based stuff works the best IMO. I've read this won't dissolve on its own in water. Is there any solution to this issue? What are the odds this would go away if I just go and add a control valve on the rough in and flush this system out.
Thank you in advance.
