O/T dryer queston
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ally68, Jun 20, 2005.
  1. ally68
    ally68 New Member
    Jan 31, 2005
    Missouri
    Not sure if you guys can help or not putting new hoses on washer and want to put new vent tubing on dryer.
    Here is my problem. my vent is only like 1 foot from my dryer outlet but about 2 inches lower and 6-10 inches to the right. What I have on ther now is a metal acordian style tube about 3-4 foot long goes out of dryer uturns then out the wall was wondering if there was any way to not have the u and so much tubing. more direct only problem is it is so close but not lined up strait.
    not sure if this makes and sense and not sure if you guys have any sugestions or not.
    Thanks in advance for any help.
  2. Kevin @ ProSpex
    Kevin @ ProSpex New Member
    May 9, 2005
    Dryer venting question
    Go to www.applianceaccessories.com and on the left side of the webpage you'll see the option "Laundry." Place your cursor on "Laundry" and a list will appear immediately to the right of the category. Move your cursor to "Dryer Venting" and click on it. It will bring up a page of dryer venting accessories including a number of offsets. One of these may do the trick for you.
  4. hj
    vent
    Home improvement centers have a metal dryer vent called a "periscope". It slides in and out to comensate for different offsets, (sometimes you have to cut off the excess if you just have a short offset), and then move the dryer into position so the periscope attaches to it. If needed a short piece of 4" metal pipe can be added if the dryer sits too far from the wall.
Similar Threads: dryer queston
Plumbing Forum, Professional & DIY Advice Where to run water lines to install washer/dryer in garage Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Moving the washer dryer and water heater? Help Jan 28, 2016
Plumbing Forum, Professional & DIY Advice Washer/Dryer vibration feet Dec 31, 2015
Plumbing Forum, Professional & DIY Advice Help with connecting my dryer up to a water line Dec 31, 2015
Plumbing Forum, Professional & DIY Advice Replacing a Bathtub with Washer and Dryer Sep 8, 2015
