Noisy Kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by A2TheMAX, Nov 30, 2004.
  1. A2TheMAX
    A2TheMAX New Member
    Nov 30, 2004
    Medically retired
    VA Beach, VA
    I have a kitchen faucet (a Moen) that when turned on full pressure, hot or cold or both, Squeels like the sound of a hot water sound. This is the only fixture in the house that does this. I've cleened the screen and h+c handles and still I'm baffled. I even took off the goose neck to see if there was any air lock. Didn't help. Not only is it anoying, it's loud and at night even louder. Any Ideas ? HELP!!! :eek:
  2. jadnashua
    Somebody else indicated that this can be caused by a washer or valve seat that is loose in the faucet. Not sure of the construction of that faucet.
  4. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    I'm trying to figure out what a "Squeels like the sound of a hot water sound" actually sounds like and why it would be "louder" at night.
    Make sure both shut off valves are fully opened, replacing the Moen cartridge will probably silence the squealing noise.
  5. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Night Noises
    When customers said louder at night I think it means there is not the usual day time noise to cover it up. My favorite customer described sound is the one that said their toilet sounded like a Whale Moaning in Heat.
    If you have a sprayer you probably have some debri in the diverter. If not then the debri could be at the cartridge.
  6. rebeljones
    rebeljones New Member
    Dec 28, 2004
    Was this problem ever resolved?
    A2themax, were you able to resolve your screaming faucet? I'm having the same trouble. Any suggestions are appreciated. Thanks!
    Rebel
  7. A2TheMAX
    A2TheMAX New Member
    Nov 30, 2004
    Medically retired
    VA Beach, VA
    Screaming Faucet
    Hey Rebel,
    Sorry man but I haven't gotten any where with the noisy thing. I'm thinking about going out and getting a new one to swap it with. Sorry I can't help ya if you have the same problem. Now if on the other hand you have suggestions, I will readily take any advie you have. I have never in my 49 years had on like this. And in my own house no less.
    :( A2TheMAX :(
  8. LonnythePlumber
    Sep 6, 2004
    Wichita, Kansas
    Debris
    Water sounds come from water moving past an obstruction. On A2Max's two handle faucet, if the noise comes from both hot and cold then it usually is in the spout. A doesn't mention if he has a sprayer and has checked the diverter to the sprayer but A does say he removed a goose neck which may be the spout. Shutting off the water and removing the cartridges and turning the water on again briefly, may clear the debris. May also make a mess. This may be a two person job.
Similar Threads: Noisy Kitchen
Plumbing Forum, Professional & DIY Advice Noisy Kitchen faucet Nov 30, 2004
Plumbing Forum, Professional & DIY Advice Noisy copper pipes Jan 14, 2016
Plumbing Forum, Professional & DIY Advice NEW TOTO DRAKE 1.6 G-MAX noisy fill? Dec 17, 2013
Plumbing Forum, Professional & DIY Advice Noisy plumbing Apr 12, 2012
Plumbing Forum, Professional & DIY Advice Noisy wastepipe in wall Jan 23, 2012
