No water from Hunter Pro C
Discussion in 'Irrigation / Sprinkler Forum' started by JDuke, Aug 11, 2007.
  1. JDuke
    JDuke New Member
    Aug 11, 2007
    I can't get the Hunter Pro C system to water. What does the flashing sprinkler head icon mean? The time runs out as if watering but nothing happens. I've looked through the online manual and it never mentions it. Iv'e never watched the controls when I was trying to run it. It was always programed to run in the night. The system was here when I moved in and all I did was turn it to run and use the program that was already programed. Also, I found something that looks like a sprinkler head that was lying in the yard. Damaged by mowing I'm sure. Iv'e turned the 2 levers in the main ground box both ways in case a plumber had turned them off. Nothing. I would appreciate some help.
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    If there is a rain detector wired into the system, a broken wire will cut the power to the valves. Any broken wire can do this, but the rain detector wiring is the most exposed.
  4. amartin725
    amartin725 New Member
    Jun 27, 2005
    The blinking sprinkler head indicates that a zone is active. If the rain detector is active, the display will show 'OFF'.
    Is it a water supply issue or a valve not turning on? You need to figure that one out. Can you turn the zones on manually? Are you feeding the system with a well?
Similar Threads: water Hunter
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Yard hydrant/automatic horse waterer question Sep 5, 2016
Irrigation / Sprinkler Forum Things to buy to do under ground water line? Aug 14, 2016
Irrigation / Sprinkler Forum How would I still have water in sprinkler lines? Mar 3, 2016
Irrigation / Sprinkler Forum Designing a sprinkler system to put water on house during brush fire Jul 22, 2015
