New Well, water test result in, need filtration recommendations
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by bewing, Apr 6, 2011.
  1. bewing
    bewing New Member
    Aug 7, 2010
    Arkansas
    Hello, I had a well drilled back in November, and finally have gotten to the point of getting a pump set and sent off for a water test. The water test is back and I need some help understanding some of the numbers and getting some help with what type of filtration I need. Here is some of the information about the well.
    Drilled Depth - 165 ft.
    Hit water at - 135 ft.
    Static Water level - 80 ft.
    Diameter - 6" rock bore
    recovery rate - 10gpm
    Pump - 3/4 hp 12 gpm pump
    Now for the test results (All results reported in mg/l unless otherwise indicated
    pH - 6.82
    Dissolved Solids - 148
    Arsenic - <0.05
    Harness - 48
    Iron - 1.00
    Manganese - 0.101
    Nitrogen, Nitrate - .260
    Sulfates - 13
    Turbidity - 22 FTU
    Total Coliform - 6 Colonies/100ml
    I don't know much about any of those numbers except that the Total Coliform scares me. The well has never been shocked, the driller didn't shock the well back in November when it was drilled, and it was never shocked after the pump was set about a month ago. Is shocking it the right thing to do and re-test. Or should I get some filtration to take care of the bacteria?
    Thanks
    Barret
Similar Threads: water test
Pumps and Tanks Well Forum & Blog. Water is life. Well Water dirty brown after home inspector's flow test Jun 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. - NO WATER: new JET pump, lines test good?? Help! May 23, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Tested - Still Low Water Pressure Apr 21, 2015
Pumps and Tanks Well Forum & Blog. Water is life. water (well) test results Apr 16, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Help! Math test on water pumping costs Apr 7, 2015
