New Tub & Drain Assembly
Discussion in 'Shower & Bathtub Forum & Blog' started by billrea99, Mar 23, 2010.
  1. billrea99
    billrea99 New Member
    Mar 23, 2010
    nj
    Hello All,
    I'm doing a bathroom remodel, which includes replacing the tub old tub that was in the bathroom with an Aquatic Symphony 9. I was limited to this tub due to the size of the alcove, however, it is a nice soaking tub. I have a Lada Ld-10103 Trip Lever Waste and Overflow waste kit. My question at this point is rather simple. When fitting the brass components together with slip nuts, do I use plumber's putty or tape? What about when the waste portion of the brass pipe fits into the plastic pvc ptrap?
    Thanks for the help. This is my first bathtub, and I want to make sure I get it right without destroying my kitchen below.
    -Bill
  2. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    You should have either plastic or rubber washers that go inside the slip joint nuts.
  4. billrea99
    Mar 23, 2010
    nj
    thanks for the help. I just wanted to make sure nothing else was required outside of the washers.
  5. jadnashua
    The washers are directional, and if installed backwards, will leak. Other than that, they work well.
  6. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    use a teflon based dope on the slip joint washers. Plumbers puddy under the strainer.
Similar Threads: Drain Assembly
Shower & Bathtub Forum & Blog Kohler tub drain assembly Aug 16, 2013
Shower & Bathtub Forum & Blog Extension for tub drain linkage assembly? Jun 7, 2013
Shower & Bathtub Forum & Blog Questions About Brass vs PVC Tub Drain Assembly To ABS Trap Sep 9, 2012
Shower & Bathtub Forum & Blog Pop-Up Drain Assembly question Oct 5, 2011
Shower & Bathtub Forum & Blog tub drain linkage assembly not stopping water Apr 25, 2011
