new toilet in cabin
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by msuchodo, Apr 3, 2008.
  1. msuchodo
    msuchodo New Member
    Apr 3, 2008
    Hello, I am planning on installing a new toilet in a cabin that is seasonal and currently only has an outhouse. i will be installing a 300 gallon septic tank this spring and the only fixture will be this toilet. The roof is sharply pitched and I am a little concerned with climbing on it to cut a vent hole.
    a couple of questions.
    1. do i need to vent if this is the only fixture on the line? (read somewhere i dont)
    2. could I use a studor vent instead of outside vent pipe?
    3. from the attached pic, which way should i vent - directly off the vertical run or can i pick up off the horizontal?
    4. do i use a sanitary T or wye for the horizontal pickup?
    thanks
  2. jadnashua
    Are there no other items that will attach to the drain? No sinks, etc? You'll need a vent for the system, and while you could probably do one from the septic tank, most people perfer to have it higher up so it can get dispursed easier (i.e., on the roof). The vent serves two purposes, allows air flow so you don't get a vacuum which can suck adjacent drains dry, and to allow the system to vent any gasses that may be generated by the wastes decomposing.
  4. msuchodo
    msuchodo New Member
    Apr 3, 2008
    Correct, there are no other items on this line, only the toilet
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A Studor (aav) vent cannot be the sole vent in a system. There must be a vent to the outside.
  6. msuchodo
    msuchodo New Member
    Apr 3, 2008
    Thanks, any thoughts on the T or Wye for the horizontal vent?
  7. hj
    vent
    The vent off the top of the tee would be one way to do it properly.
Similar Threads: toilet cabin
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Today at 8:27 AM
Plumbing Forum, Professional & DIY Advice Toilet flange too high? Thursday at 7:18 PM
Plumbing Forum, Professional & DIY Advice Option for adding to my soil stack for second toilet. Feb 10, 2017
Plumbing Forum, Professional & DIY Advice Need 10" skirted toilet in ADA Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Relocated Toilet Drain Directly Above 2x10 Floor Joist Feb 7, 2017
