new shower in basement slab
CHAPPY
i have buried a holding tank and run the piping to the general location of where the shower stall will be in a basment in concrete, do i just instal the ptrap where i want the center of the shower pan to be? is there any pitch/angles, besides down to the tank, that i must install before i put in the p trap? how do i connect the pan/strainer to the riser, will it be removable if the is a leak?
If you are going to tile the shower pan, I suggest you go over to www.johnbridge.com lots of good tiling info there.
Ideally, the drain is in the middle of your shower floor. Once the drain runs horizontal, it should have a slope of 1/4" per foot. Also note that a shower drain should be 2". You also should have a vent line running off of the drain. It depends on the type of shower pan you use how high the drain needs to be. My unprofessional experience.
