New shower drain into existing laundry drain?
Discussion in 'Shower & Bathtub Forum & Blog' started by jsr, Jul 26, 2007.
  1. jsr
    jsr New Member
    Jul 26, 2007
    I'm planning to install a new standup shower stall on the same first floor as an existing nearby laundry room. So could I conveniently drain the shower into the 2" laundry drain line in the basement that pass right by the location of the new shower stall? I'd plan on installing a 2" drain pipe and trap from the shower unit and Y into the existing 2" laundry line.
    Thanks,
    John
  2. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    if you can fit a 2" p-trap and still get 1/4" per ft. of fall, and vent it, it should be okay. the only other issue is if other fixtures tie into that 2" line.
    If there was a tub or shower there before, there should be a vent already and you could tie into it.
  4. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Where are you located? Florida code, which is loosely based on the international code prohibits venting a bathroom fixture with a non-bathroom fixture (2004 FPC 909.1). If you could get a vent in to service the bathroom you'd be good to go.
  5. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    I would check to see if you can tie into the drain - if your tie in is closer than 8' you might be out of luck (sudsing fixture)...
    As well, you would have to vent the shower on it's own (use a combo on the drain line with a san-tee above it then vent out the top and swing the trap arm to the shower drain.)
  6. jsr
    jsr New Member
    Jul 26, 2007
    I'm in Connecticut. Thanks for your replies. Guess I'll rely on local authorities on the definitive word.
    John
Similar Threads: shower drain
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
