New Shower Arm will not tighten
Discussion in 'Shower & Bathtub Forum & Blog' started by clineberry9702, Apr 4, 2005.
  1. clineberry9702
    clineberry9702 New Member
    Apr 4, 2005
    Civil Engineer
    Masaryktown, FL
    I have just redone my shower and installed cpvc piping and the shower arm when tightened will be about 30 degrees past center of the shower, hence if turned on it will hose down the bathroom if the door is open. How do I get this to tighten at the correct location. Are there gaskets or o-rings that can be inserted to solve this? I have used teflon tape, but when the arm is centered in the shower it is just too loose to even rotate the shower head without the arm twisting in place. Help???
  2. jadnashua
    Try putting a couple more turns of teflon tape on the threads. It should tighten up at a different point. Adjust more or less as needed.
  4. clineberry9702
    Apr 4, 2005
    Civil Engineer
    Masaryktown, FL
    I will try that, but was also wondering if standard pipe dope would tighten it up at all? Or can it be used on CPVC fittings?
  5. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Use teflon tape only.
    Wrap it with a little more, as jadnashua suggested, clockwise only as the threaded end of the shower arm faces you., until you can get it to stop (tightly) where you want it.
    Good luck!
    Mike
  6. clineberry9702
    Apr 4, 2005
    Civil Engineer
    Masaryktown, FL
    Thanks for the advice.
Similar Threads: Shower tighten
Shower & Bathtub Forum & Blog Could Not Tighten Shower Drain Nut W/Wrench....?? Aug 25, 2012
Shower & Bathtub Forum & Blog How to tighten loose shower pipe?? Jan 4, 2006
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Yesterday at 11:17 AM
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
