New resin for model 60
Discussion in 'Water Softener Forum, Questions and Answers' started by ChuckB, Aug 22, 2009.
  1. ChuckB
    ChuckB New Member
    Jul 30, 2009
    What is the best way to measure the .7 CF of resin needed in each tank?
    I know I can weigh it, divide by 10 and then multiply by 7, but is there an easier way? Thanks
    Chuck
  2. Gary Slusser
    Retired
    I would save time and a step by weighing the 1 cuft and multiplying that by .7.
    The only lubricant required on most o-rings used on control valves etc. today is water.
  4. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    It would be 21 quarts or 5.25 gallons.
  5. ChuckB
    ChuckB New Member
    Jul 30, 2009
    worked out pretty good.. I cut the bottom off a clean, one gallon oil container that had a big neck and used a scoop. Cleaned the tanks as recommended by Andy also. Thanks for the replies. Chuck
  6. Gary Slusser
    Retired
    Anyone buys resin from me I include a proper new funnel.
  7. Gary Slusser
    Retired
    Silicone o-rings only need water as a lubricant.
  8. Gary Slusser
    Retired
  9. ChuckB
    ChuckB New Member
    Jul 30, 2009
    Gary, Mute or Moot point. My Kinetico O-Rings are not silicone. They are Styrene-Butadiene Rubber (SBR) O-Rings and I have always used silicone grease with no problems. Thanks.
    Chuck
  10. Gary Slusser
    Retired
  11. Gary Slusser
    Retired
    If you want to tell people with silicone o-rings to lube them, and to use silicone to do it, go for it. It is not necessary, water works very well.
  12. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    Andy and Gary: I want to see if I understand the issue about lubricating o rings on softeners.
    Gary said silicone lubricant isn't required with a silicone o ring. Andy said it is ok to use silicone lubricant on o rings. I don't see a direct conflict between those statements--rather a different emphasis.
    I know that Gary is a proponent of Clack valves so I looked at the documentation for Clack WS=1 valves to see what is said about o ring lubricants. I found the following statement in more than one place: "Do not use Vaseline, oils, or other unacceptable lubricants on o-rings. A silicone lubricant may be used on black o-rings." I found no reference to using water as a lubricant in the Clack manuals I reviewed.
    So my take is that it is ok to use silicone lubricant but sometimes it may not be required. I guess the practical question that remains for me is how do I know if the o ring is a silicone o ring that doesn't require silicone lub?
  13. ChuckB
    ChuckB New Member
    Jul 30, 2009
    Gary, a more approprate statement from you would have been something like:
    "Some people use silicone on their orings, which is fine, but I have always used water and it works for me."
    and again my o-rings aren't made of silicone!
    Until they rewrite my Kinetico manual I will continue to use silicone as it recommends. It makes assembly much easier. Thanks Chuck
  14. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Tip: For those of you wishing to use silicone lube/sealer for any purpose, Lowes sells a reasonably sized, reasonably priced ($4+/-) container. Say, for the o-rings on a kitchen faucet spout.
  15. Gary Slusser
    Retired
    Silicone o-rings do not need lubrication but if you want to lubricate, water works very well.
    Clack also says to not lubricate the seals. They are silicone.
  16. Bob999
    Jul 4, 2009
    Pennsylvania
    Andy, The link you provide is to a document prepared by the online seller of softeners--It is not, as best I can tell, a Clack document.
    The quote I provided in my post above was taken from a document on the Clack website--specifically this document at page 35:
    http://www.clackcorp.com/valve/Manuals/V3115-99_WS1_1.25_Drawings_and_Service_Manual.pdf
  17. Gary Slusser
    Retired
    I read every word in that competitor's installation guide that Andy posted.
    There are many errors and omissions in it. Some errors are really bad!
    I could copy/paste them but since they are a competitor, I won't. I'll just feel bad for their Clack WS-1 customers.
    They have revised a guide used for Fleck to fit the Clack WS-1. The fit isn't very good.
    I don't know fer sure but, IIRC, silicone and sch 80 pvc may not mix well, yet they are telling their customer to use silicone with sch 80 PVC. I do know there is no need for lubricant on the o-rings on the plumbing connectors.
    Anyway, silicone o-rings do not need any lubricant but water works very well.
  18. ChuckB
    ChuckB New Member
    Jul 30, 2009
    Kinetico does not use silicone o-rings.
    You are the one to bring up silicone o-rings in this post..
    Re read everything again..
  19. Gary Slusser
    Retired
    I didn't say they did.
    What's with the attitude?
    Have you noticed that your other thread about Kinetico has been deleted? I suggest you lose the attitude or this one will probably be deleted too.
  20. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    Kinnectico is junk
    Just ran into a customer that paid 2000 for the Kinnectco
    unit, I not say a word... I know that some day he will regret it.
    the only reasons he went with
    that unit over the 999 clack was that it did not use electricity...
    the rest was all smoke and mirrors...
    I am sorry for being so insensitive,
  21. ChuckB
    ChuckB New Member
    Jul 30, 2009
    Your posts were also deleted. You should also lose your attitude.
    All I was doing was defending your misinformation. This forum should used to help others, not to sell your products.
Similar Threads: resin model
Water Softener Forum, Questions and Answers Kinetico Model 60 resin replacement Mar 21, 2014
Water Softener Forum, Questions and Answers Fine Mesh to Standard Resin question Sunday at 6:37 AM
Water Softener Forum, Questions and Answers Resin in Water Feb 12, 2017
Water Softener Forum, Questions and Answers Resin Cleaner? Jan 19, 2017
Water Softener Forum, Questions and Answers Resin leaked into plumbing Jan 5, 2017
