new pex supply line failure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chermann, Nov 25, 2009.
  1. chermann
    chermann New Member
    Nov 25, 2009
    St Louis
    Why would a new pex supply line rupture? It was connected from the faucet to the shut off valve. The compression ring was in place and in the correct position and the nut was tightened with a wrench aprox, 3/4 of a turn passed hand tight. The line was attached with no leaks for about a week and then it separated. I am no stranger to these supply lines, but I have never had one separate on me before. Kinda at a loss. Any suggestions?!?!?!?!?
  2. Inspektor Ludwig
    Inspektor Ludwig Journeyman/Inspector
    May 11, 2006
    In the good ol' UPC
    You said it was connected from the faucet to the shut off valve? The supply stop under the sink? Or did you have pex ran to the supply stop and then another material from the stop to the faucet?
  4. chermann
    chermann New Member
    Nov 25, 2009
    St Louis
    It was the supply line from the shut off valve to the faucet. Its the grey semi rigid PEX tubing that I used here for the supply line instead of the braided supply line.
  5. plumbergreg
    plumbergreg New Member
    Jun 26, 2009
    Ontario, Canada
    They are approved but I would never install one. Braided supplies under counters and rigid chrome in sight(if the homeowner wants).
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Did you use a metal ferule?
  7. jimbo
    jimbo Plumber
    Sounds like a gray PVC supply line permanently attached to the faucet??? A lot of models come that way now.. Just exactly what broke? Do you have a pic???
  8. chermann
    chermann New Member
    Nov 25, 2009
    St Louis
    the PEX supply line is connected to the faucet with a nut. I used the plastic ferule that the line came with. I don't have a pic, but the line separated (pulled out) from the shut off valve even though the ferule and nut were in place properly and then tighened down.
  9. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    you tightened the nut 3/4 of a full turn past what was hand tight to you? My guess was that the line wasn't long enough to fully insert into the valve, and the nut wasn't tight enough to compress the ferrule properly.
    And even if it was done tight enough, an outer plastic ferrule compressing on a plastic supply line without an internal stiffener is not a proper way to make the connection. No wonder the line pulled out. There is a reason why plumbers prefer to use the braided lines, because they physically compress a tapered washer to make a lasting connection!
  10. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    I have never seen a poly supply line that had an insert that you speak of.....
  11. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    There is supposed to be a metal insert that goes into the pex at the ferrule end.
  12. hj
    connection
    Poly/PEX lines do not COME with the stiffener insert, you buy them separately and use them. Without the insert tightening the nut may squeeze the tubing rather than compress the ferrule. In any case, I would never trust a "formula" such as "3/4 turn past hand tight" to make a permanent connection, after all, MY hand tight would be more or less than yours and which would be "correct" as a starting point? I tighten them as much as necessary to make sure they do not come loose. Normally that is a LOT more than 3/4 turn additional. That assumes I use them for faucet connections, which I NEVER do, but do use them for other purposes.
  13. burleymike
    burleymike New Member
    Nov 4, 2008
    Idaho
    This thread got me to thinking. Three years ago when we bought our house a lot of the old vinyl supply hoses were bulging around the crimps. I replaced them with these Pex supply lines.
    I bought them at the plumbing supply place in town. I asked the salesman if these were like an ice maker supply where you need the brass insert. He told me no and they don't even carry them.
    I guess I better replace all of them now. I think if they were going to fail they would have in three years but who knows for sure. I would rather be safe than sorry.
  14. Alan Muller
    Alan Muller New Member
    Oct 28, 2009
    Delaware
    I'm still not sure of the situation that failed. Was it a pex line installed with a rubber cone? Could you post a picture of what failed? Or examples of what failed?
Similar Threads: supply line
Plumbing Forum, Professional & DIY Advice Supply Line Pipe Type & New Stop Valve Yesterday at 1:46 PM
Plumbing Forum, Professional & DIY Advice sink supply lines roughed in wrong spot Tuesday at 1:16 PM
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Faucet Supply Line Connect Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Supply lines for roman style tub faucet? Jan 25, 2017
