RJL
Hi ,
I purchased an older home that had washer drain tied into the sink and Id like to drain this into the sink drain instead
I bought a kit in home depot and set up the water lines, and also the pvc 2" pipes to come out of the box, and down about 15 inches and then into a 90 degree elbow and continue to run the 2 inch pipe about 4 feet and then out with another 90, then reduce the 2" to 1.5" and tie into a "t" for the slop sink drain.. AM I going to have an issue with this setup running the 2" into a 1.5" drain setup or am i better off keeping it draining directly into the slop sink?
thanks in advance.
thanks in advance.
