new kitchen pipe slow draining
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by netmouse, Apr 18, 2014.
  1. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    Here are photos of 1) new piping under the kitchen sink and 2) of the new opening in the sink.
    The opening really surprised me, as you can see there is only a small hole for water to drain. Is this normal? Could this be slowing draining from the sink?
    The disposer was removed because of very slow draining, and hope that removing the disposer would speed up draining. The contractor also snaked the piping to the basement sewer pipe. I'll be having a plumber visit next.
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    You have an S-trap. You need a proper vent or AAV.
  4. jadnashua
    Not only is that an S-trap as already said, you cannot use that black rubber fitting inside of a house...those are only allowed underground where both ends of the pipe can be properly supported to keep them aligned. You need one with a metal band around it to meet code.
    Galvanized pipe can end up being VERY rough, and the rust crud can cause the interior area to be squeezed considerably. Unless you use a full-diameter cutting head on a snake, you could still have a lot of restriction in that pipe.
  5. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    I'm not a plumber. What is a proper vent or AAV? What does that entail? Why is an S-trap wrong?
  6. Kiton
    Kiton Member
    Feb 16, 2014
    Quebec
    I am not a plumber, but that galvanized pipe looks rather old and jadnashua's point should be investigated.
    This in the insides of a 68 year old vertical section of a sink drain I cut out and replaced last week in my home.
  7. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    Kiron, your pic shows one really bad pipe! Yes, I have a plumber probably here tomorrow to review what the contractor did.
  8. jadnashua
    An S-trap can actually siphon itself. A vent, on a proper drain configuration, prevents that. The seal in the trap is what prevents sewer flies, gasses, and other nasty smells from wafting up into the house.
  9. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    Your "contractor" had no business touching plumbing. The picture of their work proves they have no idea how plumbing works. No one should be allowed to take money for such poor work. Get your money back from the "contractor".
  10. hj
    An "S" trap does not necessarily "cause" slow drainage, in fact the opposite is usually true, but in combination with a problem ELSEWHERE it will drain slowly. The "elsewhere" could be anywhere in the entire system and an AAV would NOT improve the drainage in that case. You need a competent plumber, and not all are competent, to see where the problem is and cure THAT, the address the "S" trap issue which is a different matter altogether.
  11. netmouse
    netmouse Member
    Aug 7, 2012
    NJ
    Problem solved. The pipe was really snaked for a while this time. It was 15' of pipe to the sewer pipe. He said he could feel a small opening, then debris fell and completely closed it up. He kept snaking and then the drain popped open with good water flow.
    Thanks everyone for your input.
Similar Threads: kitchen pipe
Plumbing Forum, Professional & DIY Advice Hissing sound through pipes when turning on kitchen faucet Wednesday at 9:45 AM
Plumbing Forum, Professional & DIY Advice Fixing Pipes in Basement Under Kitchen Sink Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Drain pipe outside of kitchen sink on exterior wall Aug 22, 2016
Plumbing Forum, Professional & DIY Advice What Is This Pipe Under My Kitchen Sink, And Can I Get Rid Of It? May 5, 2016
Plumbing Forum, Professional & DIY Advice New kitchen sink/garbage disposal but PVC pipe problems... Apr 8, 2016
