New faucet supply lines whistle
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by johnnyi, Nov 25, 2009.
  1. johnnyi
    johnnyi New Member
    Nov 25, 2009
    tn
    Just installed a new Delta kitchen faucet. Installed without a problem however when hot or cold water is on at a low flow the faucet supply lines under the sink whistle. The whistle varies with the flow and then dissapears at full on. The new Delta faucett supply lines are plastic and replaced the original rigid copper lines to the old faucet. the pitch of the whisle also changes when supply lines are moved with water running throught them. The house is 2 years old and the plumbing is PVC. Any idea of what could be causing the whistle? There were no noises prior to the new installation and the kitchen faucet is the only faucet making noise. Any help would be appreciated.
  2. jadnashua
    Are the shutoff valves under the sink open all the way?
Similar Threads: faucet supply
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Faucet Supply Line Connect Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Supply lines for roman style tub faucet? Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Off center water supply line for bathroom faucet Feb 15, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Faucet Supply Line and Valve Size? Jan 16, 2016
