New Bathtub drain into PVC Copper CI
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BSwanson, May 17, 2006.
  1. BSwanson
    BSwanson New Member
    May 12, 2006
    New York
    I removed a tub with an old drum trap and copper drain that went into a Cast Iron soil pipe on the second floor. I have acess to the cast pipe, but it's in a tough spot. The contactor cut the copper drain pipe before it went into the cast. The new tub has PVC for a drain. All that has to be done is to connect them....and they will be in the ceiling, can I use a no hub steel sleeve type Fernco connector between the copper and the PVC? If not, how can it be done?
    Thanks for your help!
Similar Threads: Bathtub drain
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Bathtub drain setup Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Bathtub Drain Sep 18, 2016
Plumbing Forum, Professional & DIY Advice Is this an S-trap from my bathtub drain? Aug 28, 2016
