New Bathroom Faucet Water Connections
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Ecooper77, May 29, 2013.
  1. Ecooper77
    Ecooper77 New Member
    May 26, 2013
    Dallas
    Hi guys! So, over the weekend I went in to relace my bathroom faucet. I got all the old stuff out then went to Lowe's to get the water supply lines (that I'd naively assumed would come with the new faucet). I get home and the new supply lines don't fit the old (1955) copper water valve connections. Is there some sort of connector that will hook the new, braided water lines to the old copper connector heads? I've attached some images for clarity. Your help is much appreciated!
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    I would replace the valves. The one's you have are for a flair connection.
    John
  4. jadnashua
    Anytime you're refreshing the valve, it's a good idea to replace the shutoff valves as well. Those look like they are soldered on, but there appears to be enough length to just cut them off and use a compression valve (depends on the brand but most require about 1", plus some extra if you add new eschutions). You will need to polish off all of the paint or whatever is there down to bright copper to get a compression valve to seal properly. Or, once you've got it cleaned up, you could solder on new ones. While you have things apart, you can get new eschutions to slide over the pipe stub for a couple of bucks more.
  5. Ecooper77
    May 26, 2013
    Dallas
    thanks for your help guys!
Similar Threads: Bathroom Faucet
Plumbing Forum, Professional & DIY Advice Remodel cover plate for deck mounted bathroom faucets Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Bathroom faucets only trickling water, kitchen is fine Jan 4, 2017
Plumbing Forum, Professional & DIY Advice Moen Monticello. Trying to Remove Bathroom Faucet Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Question about 1950's bathroom sink faucet Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Bathroom face wash faucet drainage and kitchen sink noise Oct 22, 2016
